Include/Exclude List
This filter mode allows to include or exclude a set of values from a given column. It consists of a Free Text filter used for finding values to include or exclude and a list of values that are currently used in the filter.
NOTE |
· The search bar is the same as the Free Text filter such that only 10 items that match the current search setting are loaded. · There is no Select All option. When there is no value, this means no filtering will be done in both the Include or Exclude mode.
When entering a value, matches are displayed allowing you to pick one from the list. You can do so by double-clicking on it.
The selected column value is displayed under the Include/Exclude button.
For the example above, the column value is included in the filter.
Click Exclude to exclude this column value in the filter,
Click to delete a column value from the Include/Exclude list.
