Ratio
The comparison between the sum of a selected measure divided by the sum of the selected weight measure.
The formula:
Ratio = sum(selected measure) / sum(selected weight measure)
Sample
Given the sample data:
Region |
Store |
Actual |
Target |
North |
A |
$1,300 |
$2,000 |
North |
B |
$750 |
$1,000 |
North |
C |
$2,100 |
$3,000 |
South |
D |
$4,700 |
$4,000 |
South |
E |
$2,000 |
$2,000 |
Sample fields
Creating a Table visualization with Breakdowns Region and Store with subtotals and grand totals produces:
Actual |
Target |
North
A |
$1,300 |
$2,000 |
B |
$750 |
$1,000 |
C |
$2,100 |
$3,000 |
North Total |
$4,150 |
South
D |
$4,700 |
$4,000 |
E |
$2,000 |
$2,000 |
South Total |
$6,700 |
$6,000 |
Grand Total |
$10,850 |
$12,000 |
Setting the Column to Actual and the Weight Column to Target with the format set to 0.0% results to the following Ratio values:
Actual |
Target |
Ratio |
North
A |
$1,300 |
$2,000 |
65.0% |
B |
$750 |
$1,000 |
75.0% |
C |
$2,100 |
$3,000 |
70.0% |
North Total |
$4,150 |
South
D |
$4,700 |
$4,000 |
117.5% |
E |
$2,000 |
$2,000 |
100.00% |
South Total |
$6,700 |
$6,000 |
111.7% |
Grand Total |
$10,850 |
$12,000 |
90.4% |
The results per row
Computation details:
North A: $1,300 / $2,000 = 65.0% |
South D: $4,700 / $4,000 = 117.5% |
North B: $750 / $1,000 = 75.0% |
South E: $2,000 / $2,000 = 100.00% |
North C: $2,100 / $3,000 = 70.0% |
South Total: $6,700 / $6,000 = 111.7% |
North Total: $4,150 / $6,000 = 69.2% |
Grand Total: $10,850 / $12,000 = 90.4% |
Collapsing the North region results to the following Ratio values:
Actual |
Target |
Ratio |
North Total |
$4,150 |
$6,000 |
69.2% |
South
D |
$4,700 |
$4,000 |
117.5% |
E |
$2,000 |
$2,000 |
100.00% |
South Total |
$6,700 |
$6,000 |
111.7% |
Grand Total |
$10,850 |
$12,000 |
90.4% |
The results per row
The rest of the computation details are the same except for the collapsed North region:
North = ($1,300 + $750 + $2,100) / ($2,000 + $1,000 + $3,000) = 69.2%
Or
North = $4,150 / $6,000 = 69.2%
Collapsing the South region results to the following Ratio values:
Actual |
Target |
Ratio |
North |
$4,150 |
$6,000 |
69.2% |
South |
$6,700 |
$6,000 |
117.5% |
Grand Total |
$10,850 |
$12,000 |
90.4% |
The results per row
The computation details for the collapsed South region:
South = ($4,700 + $2,000) / ($4,000 + $2,000) = 117.5%
Or
South = $6,700 / $6,000 = 117.5%
