Setting the Default Aggregation for Numeric Columns
Setting the default aggregation of numeric columns can be done on the Columns pane of the Edit Data Table layout.
1. On the Data Sources pane, click a data source to display its settings.
2. Click Columns. The Columns pane displays with the list of available columns in the data source.
3. Click the drop-down list and select the Default Aggregation for the numeric columns. Default is Sum.
To revert to the default original
default aggregation (Sum),
click
4. Click . The new default aggregation for the
numeric column is applied and displayed on the Data Preview.
