Modification of the Numeric or Date/Time Column Format
The format of the numeric or Date/Time columns retrieved from the data source can be modified.
1. On the Data Sources pane, click a data source to display its settings.
2. Click Columns. The Columns pane displays with the list of available columns in the data source.
3. Click the drop-down list and select the Format for the numeric or Date/Time column.
Once
the column format is modified, the button
is displayed. Click this button to revert to the original column format.
4. Click . The new column format is applied and
displayed on the Data Preview.
