Configuring SSO
To use SSO
1. Open Administrator.
NOTE |
In Monarch Server that is upgraded from previous versions (e.g., v13.2), the virtual folders could still be labeled as “DSAdmin” (or “DSClient”). In this case, use “DSAdmin” (or "DSClient”) instead of “MSAdmin” (or “MSClient”) to open the Admin (or Client) page. |
2. Under the Navigation Tree, click Show Advanced Options.
3. Click on Rights and Privileges, and then choose Security Provider.
4. Under Security Providers, select Active Directory, and then select Show SSO.
NOTE |
q Mapping/aliasing of at least one administrator user is required. If there are no users mapped (MS and AD users are the same), the MS application is inaccessible without direct database modification of the Configuration table to the default state. q To add an administrator user account, choose Users under Rights and Privileges in the Navigation Tree. In the Users window, click on “+” to add a new user. |
In the User window, provide the necessary details. To check if the user account you are creating already exists, click on Check User. Do not forget to click Save.
5. Modify the file web.config of the Administrator application (the path is C:\inetpub\wwwroot\MSAdmin).
NOTE |
This step is crucial. To avoid potential application issues, make a backup of the web.config file before making any changes. |
a. Disable the following code:
<authentication mode="">
<forms loginUrl="~/Login/LoginRedirect" defaultUrl="~/Login/LoginIndex" cookieless="UseCookies" timeout="15" name=".ASPXFORMSAUTH" slidingExpiration="true"/>
</authentication>
b. Enable the following code:
<authentication mode= "Windows" />
<authorization>
<deny users="?" />
</authorization>
6. Make sure that Windows, ASP.NET Impersonation authentication on IIS for the Administrator application is disabled.
a. Go to Start > All apps > Windows Administrative Tools > Internet Information Services (IIS) Manager.
b. Go to MSAdmin > Authentication, and disable ASP.NET Impersonation status.
7. Restart the Monarch Server Config and Monarch Server Agent Services, IIS.
8. On the login page of the Administrator application, click the SSO button.
NOTE |
If you fail to define at least one administrator user and cannot login to the Administrator page, edit the Configuration table, and set the OptionValue of SecurityProvider to DEFAULT. The steps are as follows: a. Open Microsoft SQL Server Management Studio. b. In the Object Explorer panel, click Databases, and choose the database you are using. (You may check the database name using the Monarch Server Configurator. Under Configurator, click the Instances tab. The Database Name is shown in the Global Settings window. Refer to the image below.)
c. Under Tables, right-click on dbo.configuration, and then choose Edit Top 200 Rows. d. Look for the OptionId “SecurityProvider,” and then change its OptionValue to DEFAULT (case sensitive).
