Software Requirements
Server software:
q NET framework 4.7.2 32/64-bit
q SQL Server 2016/2017/2019 (if the Automator database is present on the local machine)
Operating systems:
q Windows Server 2016 (IIS 10.0 v1709)
q Windows Server 2019 (IIS 10.0 v1809)
Additional system software components:
The following components are installed automatically by the installation program if not present on the machine. You may consider installing them at the most convenient time (for example, a scheduled maintenance window) as the installation may require system reboots.
q .NET framework 4.7.2
q Microsoft Access 2013 Runtime
q Microsoft SQL Command Line Utilities 11 for SQL Server (if the Automator database is not present on the local machine)
q Microsoft ODBC Driver 11 for SQL Server (if the Automator database is not present on the local machine)
q SQL 2017 Local DB
Client software:
q One of the following browsers:
· Internet Explorer 11
· Mozilla Firefox v95.x+
· Google Chrome v96.x+
· Microsoft Edge (Chromium Engine) v96.x+
NOTE |
Compatibility of future browsers may require Automator patches as a result of changes by browser vendors that compromise historic functionalities and behaviors. |
