Admin
The default path to the file is as follows: C:\inetpub\wwwroot\MSAdmin\web.config.
The parameters listed below are located in the <appSettings> of the MSAdmin.
The recording format of each of the parameters is as follows:
<add key="parameterName" value="parameterValue" />
PARAMETER NAME |
DESCRIPTION |
DEFAULT VALUE |
loginOutOnBrowserCloseEnabled |
Enable immediate session termination when the browser or browser tab is closed. |
false |
