Representing Null Values in the Table View
When a table cell evaluates to null, Monarch Classic displays a user-defined string to represent the null value. Null values are displayed in the Table window when:
Calculated field expression causes division by zero
Field imported from an external database contains null values
The default string used to represent null values is "(Null)", but you can specify any string you like.
On the Home ribbon, select Options. The Options window displays.
Select View from the Options window ribbon to display the View Options window.
Enter the text string in the Display null values as box.
To save this string as the default for future Monarch Classic sessions, select Accept. To restore the previously saved default, select Cancel.
