Altair® Monarch®
Finding Information in a Report
Monarch Classic's search bar allows you to search for information in a report:
You can search for any text, including letters, numbers, spaces and punctuation.
  1. Press CTRL + F to bring up the Search Bar.
  2. Type a search string in the Search box. You may enter up to 128 characters, including letters, numbers, spaces and punctuation.
  3. Set the search options:
    • Check the Search Up box to search backward through the report,
    • Check Wrap if you wish to search for the word even if it wraps to the next line.
    • Check Match Case to perform a case-sensitive search.
    • If multiple reports are open, you can also select Search All Reports to carry out the search across all open reports.
  4. Click on Find Next to initiate the search. Keep clicking on Find Next to search further down (or up) the document.
  5. To quit searching, close the Search Panel by selecting CTRL+F or by selecting the red X at the right side of the search panel.
