Adding and Removing Imported Fields
Occasionally, you may want to review the list of fields imported from an external database and select additional fields to import, or remove one or more of the fields you previously selected to import.
The Database option from the Table Design Ribbon allows you to do this easily.
Adding and removing imported fields
Go to Table Design.
Select Database from the Table Design Ribbon. (Note: The Database option is only available if you used a database as a data source.)
Add or remove fields by selecting checkboxes on the Select column of the Import Fields tab. You may also use the Select All or Deselect All buttons to select or unselect all fields.
Click Accept to accept all changes..
Monarch Classic re-displays the table, adding any new columns you selected and removing any previously imported columns you deselected.
