Address Block
Address blocks provide a way to parse address text into its component parts. An address block definition includes its name, postal code format flags (the type of postal codes it recognizes), a set of one or more input fields, and a set of output fields. Address blocks are created via the Address Block wizard. See Using Address Blocks for more information.
