Altair® Monarch®
Using Aggregations
Monarch Classic includes aggregations which you can use to perform arithmetic functions on the values of a measure in a summary. The following types of aggregations are available in the Edit Measure Expression dialog:
Cumulative aggregations
Aggregation
Cum()
Returns the cumulative sum.
CumCount(*)
Returns the cumulative row count.
CumCountPct(*)
Returns the cumulative row count as a percentage of the total rows.
CumPct()
Returns the cumulative sum as a percentage of the total sum.
Count aggregations
Aggregation
Count(*)
Returns the count of rows (or non-null values of the field) within the group.
CountPct(*)
Returns the group row count as a percentage of the total rows.
CountSubPct(*)
Returns the group row count as a percentage of the row count in the next larger group.
CumCount(*)
CumCountPct(*)
Percentage aggregations
Aggregation
CountPct(*)
CountSubPct(*)
CumCountPct(*)
CumPct()
Pct()
Returns the group sum as a percentage of the total sum.
SubPct()
Returns the group sum as a percentage of the group sum of the next larger group.
Statistical aggregations
Aggregation
Avg()
Returns the average value of the field within the group.
Max()
Returns the maximum value of the field within the group.
Min()
Returns the minimum value of the field within the group.
Stdev()
Returns the standard deviation of the field values within the group.
StdevP()
Returns the standard deviation (with respect to the population) of the field values within the group.
Sum()
Returns the sum of the field values in the group.
Var()
Returns the variance of the field values within the group.
VarP()
Returns the variance (with respect to the population) of the field values within the group.
Special aggregations
Aggregation
Unique()
Returns the unique value of the field if there is a unique value, otherwise returns null.
