Pivot Value Dialog
Use this dialog to specify aggregations for values in your pivot table.
options
Field |
Description |
Summarize
value field by |
Instructs
Monarch Classic
to apply any of the following functions to the values:
Sum
- The sum of the values. This function is the default for
numeric data. If the field being aggregated contains blanks
or non-numeric data, the Count function is applied instead.
Count
- The number of non-empty values. This function is the default
for data types other than numeric.
Average
- The average of the values.
Max
- The largest value.
Min
- The smallest value.
Product
- The product of the values.
CountNums
- The number of data values as numbers
StdDev
- An estimate of the standard deviation of a set of values.
StdDevp
- The standard deviation of all of the values.
Var
- An estimate of the variance of a set of values.
Varp
- The variance of all of the values.
Show
value as |
Normal - Displays the value entered in
the field
% of row - Displays the values in each
row as a percentage of the row total
% of column - Displays the values in each
column as a percentage of the column total
% of total - Displays values as a percentage
of the grand total of all values
Number
format |
Applies a number
format to the values (General, Thousands, Currency, Percentage,
Time Span) |
Decimals |
Specifies the
number of decimal places to add to the values. |
