Altair® Monarch®
Opening a Workspace
When you open a saved workspace, all of the tables, data prep operations, combinations, and transformations you applied in the Data Prep Studio session you used to create the workspace from are loaded.
  1. Select the Application Menu icon on the upper right corner of the window you are in:
  1. Select Open Workspace.
  1. Use the Open dialog that displays to locate the workspace you previously saved, select it, and then click Open.
    The workspace is loaded into Data Prep Studio.
  2. NOTE: The current version of Monarch Data Prep Studio no longer supports integration with Altair Knowledge Hub. Thus, when a workspace containing tables imported from Knowledge Hub is opened, the error message "Monarch Data Prep Studio no longer supports integration with Altair Knowledge Hub" displays.
