Altair® Monarch®
Open Web File Dialog
Use this dialog to define the connection to your Web Server or FTP site.
This dialog displays when you select Web File as your data source from the Open Database dialog.
Options
Field
Address
Enter the URL or Web Server Address. This address must include http:// or ftp://
If you were using an FTP site the address could be: ftp://user.mysite.com/
Note:  If you have entered addresses in previous open web file operations, you can use the drop-down button to display a list of existing addresses.
Connect
Connect to the Address specified, using credentials you have entered in the Security Options dialog.
Cancel
Cancels the open web files operation and closes this dialog box.
Help
Displays this help topic.
