Altair® Monarch®
Function: YearFrac
Calculates the fraction of the year represented by the number of whole days between two dates. For instance, you can use YearFrac to identify the proportion of a whole year's benefits, or obligations to assign to a specific term.
YearFrac([start_date],[end_date],[basis]).
Arguments
  • start_date and end_date can be a constant, a date field, an expression that results in a date or a function that returns a date.
  • basis is optional and can have one of the following values:
Basis
Meaning
0 or blank
US (NASD) 30/360
1
actual/actual
2
actual/360
3
actual/365
4
European 30/360
Return value
This function returns a number.
Calculated field example
For the following dates:
Argument
Sample Value
Start_Date
1/1/2012
End_Date
7/30/2012
YearFrac([start_date],[end_date]) = 0.58055556
Argument
Sample Value
Start_Date
1/1/2020
End_Date
7/1/2020
YearFrac([start_date],[end_date]) = 0.5000
(This indicates that 7/1/2020 is the midpoint, or 1/2,of the year 2020)
