Altair® Monarch®
Function: Upper
Converts a string to uppercase letters.
Upper(string)
Arguments
string can be a constant, a character field, an expression that results in a string or a function that returns a string.
Return value
This function returns a character string.
Calculated field example
If the State field contained the value Mi, the following calculated field expression would return MI: Upper(State)
Filter/Find example
All filter expressions are case insensitive, so Upper has no practical application here. For find expressions, use the Match Case setting to determine case sensitivity.
