Function: Space
Returns a string consisting of a specified number of spaces.
Space(number)
Arguments
number is the number to convert.
Return value
This function returns a character string.
Calculated field example
If the Product field contains the following classical music recordings, you could use the Space function to create a new field with the composer and the symphony separated into distinct columns.
Initial field values
"Dvorak, Concerto for Cello"
"Gershwin, An American in Paris"
"Mozart, Symphony in D, K.202"
The following calculated field expression would create a new field with the composer in one column and the symphony in a second column:
LSplit(Product,2,",",1)
+Space(18-Instr(",",Product))
+LSplit(Product,2,",",2)
The first part of this expression LSplit(Product,2,",",1) splits off the composer from the Product field. The second part +Space(18-Instr(",",Product)) concatenates a variable number of spaces, based upon the length of the composer name, to create space between the first and second columns of data. The third part of the expression +LSplit(Product,2,",",2) concatenates the symphony as the second column of data. The result is shown below:
Resulting
field values
"Dvorak Concerto for Cello"
"Gershwin An
American in Paris"
"Mozart Symphony in D, K.202"
