Altair® Monarch®
Function: RedactSSN
The RedactSSN function is a redaction function that can be used in calculated field expressions.
Numeric digits are replaced with random digits, but adjusted so that the resulting SSN number is not valid.
This function produces redaction results equivalent to Pseudo NHS Number in Input Field Properties Window.
RedactSSN(text)
Arguments
Text may be any text field containing an SSN number.
Return Value
This function returns an SSN-looking number, but adjusted so that the resulting SSN number is not valid. Any non-digit characters in the input text are preserved.
Calculated field example
You can create the following expression: RedactSSN(SSN)
If NHS = 078-05-1120, the result can be something like: 923-00-3744.
