Altair® Monarch®
Function: RedactBankNumber
The RedactBankNumber function is a Redaction function that can be used in calculated field expressions.
RedactBankNumber replaces numeric characters with random digits, but adjusted so that the resulting number still looks like a bank number but has an incorrect Luhn algorithm check digit. (A Luhn algorithm is used to validate a variety of identification numbers, such as credit card numbers, IMEI numbers, National Provider Identifier numbers in US and Canadian Social Insurance Numbers.)
This function produces redaction results equivalent to Pseudo bank card number in Input Field Properties Window.
RedactBankNumber(text)
Arguments
Text may be any valid bank number (e.g. a credit card number).
Return Value
Returns a pseudo bank card number.  Any non-digit characters in the input text are preserved.
Calculated field example
You can create the following expression: RedactBankNumber(CreditCardNo)
If CreditCardNo = 5610-5910-8101-8250, the result can be something like: 5022-1016-2906-5179.
