Altair® Monarch®
Function: RTrim
Removes all spaces from the end of a string.
RTrim(string)
Arguments
string can be a constant, a character field, an expression that results in a string or a function that returns a string.
Return value
This function returns a character string.
Calculated field example
If the Firstname field contained the value "Santa   ", the following calculated field expression would return "Santa": RTrim(Firstname)
Filter/Find example
Records with a Firstname field value of "Tom" or "Tom   " can be selected or found using the expression: RTrim(Firstname)="Tom"
