Altair® Monarch®
Function: Now
Returns the current date and time.
Now()
Arguments
no arguments required
Return value
This function returns the current date and time using the general date/time (long time) format (e.g. : 02/09/2017 11:04:32 PM)
Calculated field example
You can use Now() to calculate the number of days that have elapsed from a specific date:
Billdate - Now()
Where Billdate must be a field with a date format.
If today is August 15, 2017, you will get the following results:
