Altair® Monarch®
Function: IsUpper
Returns 1 if character is uppercase alphabetic, otherwise returns 0 (zero).
IsUpper(character)
Arguments
character can be a constant, a character field, an expression that results in a string or a function that returns a string. If character is longer than a single character, IsUpper operates on only the first character.
Return value
This function returns a number: 1 if character is uppercase alphabetic, otherwise it returns 0 (zero).
Calculated field example
The IsUpper() function has no practical application in a calculated field expression.
Filter/Find example
Records with a Part_no field that have an uppercase alphabetic character in the third character position (75T versus 75t) can be selected or found using the expression: IsUpper(Substr(Part_no,3,1))=1
