Altair® Monarch®
Function: Extract
Extracts a substring between a starting string and an optional ending string. The string to delimit the start of the desired substring must be specified. The string to delimit the end of the substring is optional. If the second argument is not found the function extracts everything from the starting string to the end of the field. The case of the delimiting string is ignored.
Extract(string,start string[,end string])
Arguments
string is the string containing the substring. The string can be a constant, a character field, an expression that results in a string or a function that returns a string.
start string is the string delimiting the start of the desired substring.
end string is the optional string delimiting the end of the desired substring.
Return value
This function returns a character string.
Calculated field example
If the Letters field contained the value of abc[def]ghi, the following calculated field expression would return def: Extract(Letters,"[","]")
Filter/Find example
Records with a Letters field value of def can be selected or found using the expression: Extract(Letters,"[","]")="def"
