External Functions Library Dialog
Use this dialog to add external models and their corresponding external functions.
Select Functions from the Table Design ribbon.
Select Manage External Functions from the User-Defined Function Definition Window.
Field |
Description |
External Models |
Lists models that have been linked. |
Functions |
Lists the functions that are available from each model. |
Add External Model |
Allows to select and then add another model to the list, using the Add External Model Dialog. |
Remove External Model |
Allows you to delete an external model from the list. You must select a model from the External Models list first. |
Edit External Model |
Allows you to edit an External Model property. For instance, you can change the link type. |
OK |
Accepts all changes and closes the dialog. |
Cancel |
Rejects all changes and closes the dialog |
Help |
Displays this help topic. |
