Editing a Template Definition
You can edit a template to change its name, type, trap, sample data, or field definitions.
Open the Report Design window and then select the template you wish to edit from the Template and Field Properties panel.
The selected template's properties are displayed on the Template Editor. Make the desired changes to the template definition.
Commit your edits by doing one of the following:
Select another template from the Template and Field Properties panel.
Select the Accept button on the Report Design toolbar.
