Editing a Summary in Data Prep Studio
You can edit a summary to change its name, select a different filter to apply when building the summary, add or remove key fields, measures or item fields, or edit the properties of key, summary, or item fields
To edit a summary:
Click the Analyze tab to display the Summary options
Select the summary to edit from the Summary drop-down.
Click the Edit Summary button.
The Edit Summary dialog displays. This dialog will show all of the details you specified when you created the original summary. Using this dialog, you can:
Edit the properties of individual columns in the summary
Change the order of the columns
Insert a total line to the summary
Modify the calculation assigned to a given measure
