Creating Calculated Fields
Creates a new column based on a calculation.
Steps
Right+Click on a column and select Create Calculated Field... from the context menu. The Create Calculated Field dialog displays:
Enter the new column name.
Define the expression for calculating the new field value:
Select fields, operators, functions, and operators from the lists above the expression builder.
If you are new to expressions, read this page to help you
Refer to Functions Reference for a list and description of all functions you can use within an expression.
exampleS
In this example, the first column (Amount) is the original column. Discount is a calculated field that shows the 10% discount value. It uses the following simple formula: Amount * .10:
Other expressions can look like this:
If(Customer="Ace Resellers",Unit_price*.55, Unit_price*.65)
FiscalWeek([Ship Date])
Replace(Contact,"Smith","Smith-Jones")
