Converting Columns Using the Data Type Icon
Icons on the header readily tell you a column's data type:
Date/Time
Number
Text
You can quickly convert from one data type to another in the Prepare window following these steps:
Select a table containing a column with a data type you want to convert.
Click on the data type icon beside the name of this column.
Select the new data type from the list that displays.
