Connector Dialog for Business Objects
Enter values into the dialog box to connect and fetch data from your Business Objects data source.
Options
Field |
Description |
Host |
The name of the machine or domain containing the data source. This host must be accessible from the box where Monarch Data Prep Studio is installed. |
Port |
Port Number required to access the data source. |
User Name |
A valid User Name required to log-on to the host. |
Password |
A valid Password required to log-on to the data source. This password must match the User ID above. |
Authentication Type |
Select one of the following:
Use the system default Enterprise Authentication if you prefer to create distinct accounts and groups for use with BusinessObjects Enterprise, or if you have not already set up a hierarchy of users and groups in a Windows NT user database, an LDAP directory server, or a Windows AD server.
If you set up an LDAP directory server, you can use existing LDAP user accounts and groups in BusinessObjects Enterprise. When you map LDAP accounts to BusinessObjects Enterprise, users are able to access BusinessObjects Enterprise applications with their LDAP user name and password. This eliminates the need to recreate individual user and group accounts within BusinessObjects Enterprise.
If you are working in a Windows 2000 environment, you can use existing AD user accounts and groups in BusinessObjects Enterprise. When you map AD accounts to BusinessObjects Enterprise, users are able to log on to BusinessObjects Enterprise applications with their AD user name and password. This eliminates the need to recreate individual user and group accounts within BusinessObjects Enterprise.
Use SAP R/3 Authentication. |
Request Timeout |
Amount of time the application will wait for a response from the Server before declaring a timeout error. |
Connect |
Click to connect to the host using the log-in information specified in this dialog. |
Selected Universe |
The name of the universe which you want to connect to. |
Selected Items |
Select the objects you want to work with |
Filters |
Select the filters you want to apply on the objects. |
Preview Data |
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data. |
Validate |
Click to check that the query created is correct. |
