Altair® Monarch®
Connector Dialog for Altair Monarch Server
Enter values into the dialog to connect to and fetch data from your Altair Monarch Server library data source.
Options
Field
Monarch Server Client URL
URL used to connect to the Monarch Server.
Username
A valid Username for the Monarch Server.
Password
A valid Password required to log-on the data source. This password must match the User ID above.
Connect
Click this button after you have specified the Server, Username, and Password. After a successful connection, you select a report.
Document Type Group
Select a Document Type Group from the drop-down. The list depends on the access rights defined for the current user.
Select a Document Type from the drop-down. The list depends on the access rights defined for the current user, as well as the Document Type Group initially selected.
Model
Select the Model you want to use for the document.
Report Date
Allows you to set a Date Range. Only documents that fall within this date range will be returned.
Report
Displays a list of reports that meet the criteria defined above. Highlight the reports that you want to use.
View
Select the view that you want to use.
Summary Name
Select the Summary that you want to be applied. The list displayed here depends on the Model that you selected above.
NOTE: The Altair Monarch Server connector for Data Prep Studio only functions if the Monarch Server security settings are set to Default. Other settings, such as Active Directory, are not yet supported in DPS.
