Altair® Monarch®
Add Bookmark Dialog
Use this dialog to add or edit a bookmark comment. This dialog displays when you select Bookmark on the Report View Ribbon.
Options
Field
Comment Field
Enter the comment you want to annotate the bookmark with here.
Show when adding
Select if you want the Bookmark Comment dialog to display whenever you add a bookmark. If you don't want the dialog to display in the future, you may clear this checkbox.
To access this dialog after clearing this checkbox, right-click on a bookmarked line and select Edit Bookmark Comment from the context menu.
OK
Saves the current settings and closes the dialog.
Cancel
Cancels any changes and closes the dialog.
Help
Displays this help topic.
