Where are the Run Files?
  1. On the Analysis icon, click the Run History icon.
  2. On the Run History dialog, right-click a run, then select Open Run Folder.
    The files from your analysis are generally saved to the Run folder unless specified otherwise in File > Preferences > Run Options.
