User Triangular Shell Elements Using Solid Property Example
A triangular shell property is defined using a user solid property with rotational degrees of freedom at nodes.
Example Demo File
<install_directory>/hwsolvers/demos/radioss/User_Subroutines/4_user_property_elements/brick/
