Engine Subroutine SUSERnn for Solid Elements
This subroutine calculates the internal forces and moments.
Arguments
C--------------------------------------------------------------------------
SUBROUTINE SUSER29(
1 NEL ,NUVAR ,IOUT ,IPROP ,IMAT ,SOLID_ID,TIME ,TIMESTEP,
2 EINT ,VOL ,UVAR ,FR_WAVE,OFF ,RHO ,SIG ,
3 XX1 ,XX2 ,XX3 ,XX4 ,XX5 ,XX6 ,XX7 ,XX8 ,
4 YY1 ,YY2 ,YY3 ,YY4 ,YY5 ,YY6 ,YY7 ,YY8 ,
5 ZZ1 ,ZZ2 ,ZZ3 ,ZZ4 ,ZZ5 ,ZZ6 ,ZZ7 ,ZZ8 ,
6 UX1 ,UX2 ,UX3 ,UX4 ,UX5 ,UX6 ,UX7 ,UX8 ,
7 UY1 ,UY2 ,UY3 ,UY4 ,UY5 ,UY6 ,UY7 ,UY8 ,
8 UZ1 ,UZ2 ,UZ3 ,UZ4 ,UZ5 ,UZ6 ,UZ7 ,UZ8 ,
9 VX1 ,VX2 ,VX3 ,VX4 ,VX5 ,VX6 ,VX7 ,VX8 ,
A VY1 ,VY2 ,VY3 ,VY4 ,VY5 ,VY6 ,VY7 ,VY8 ,
B VZ1 ,VZ2 ,VZ3 ,VZ4 ,VZ5 ,VZ6 ,VZ7 ,VZ8 ,
C VRX1 ,VRX2 ,VRX3 ,VRX4 ,VRX5 ,VRX6 ,VRX7 ,VRX8 ,
D VRY1 ,VRY2 ,VRY3 ,VRY4 ,VRY5 ,VRY6 ,VRY7 ,VRY8 ,
E VRZ1 ,VRZ2 ,VRZ3 ,VRZ4 ,VRZ5 ,VRZ6 ,VRZ7 ,VRZ8 ,
F FX1 ,FX2 ,FX3 ,FX4 ,FX5 ,FX6 ,FX7 ,FX8 ,
G FY1 ,FY2 ,FY3 ,FY4 ,FY5 ,FY6 ,FY7 ,FY8 ,
H FZ1 ,FZ2 ,FZ3 ,FZ4 ,FZ5 ,FZ6 ,FZ7 ,FZ8 ,
I MX1 ,MX2 ,MX3 ,MX4 ,MX5 ,MX6 ,MX7 ,MX8 ,
J MY1 ,MY2 ,MY3 ,MY4 ,MY5 ,MY6 ,MY7 ,MY8 ,
K MZ1 ,MZ2 ,MZ3 ,MZ4 ,MZ5 ,MZ6 ,MZ7 ,MZ8 ,
L STIFM ,STIFR ,VISCM ,VISCR )
Argument | Format | Description |
NEL | Integer read only scalar | Number of elements per group. In Radioss Engine subroutines, the element data are treated by groups for vectorization. This argument is machine-dependent and set by Radioss. |
NUVAR | Integer scalar | Number of extra variables needed for each solid element in SINInn or SUESERnn |
IOUT | Integer read only scalar | Output file unit (L01 file) |
IPROP | Integer read only scalar | Property number. |
IMAT | Integer read only scalar | Material number. |
SOLID_ID | Integer read only scalar | Array of size NEL containing solid element ID. |
Time | Float read only | Current time. |
TIMESTEP | Float read only | Current time step. |
EINT | Float array read only | Array of size NEL containing current total internal energy. |
VOL | Float array read only | Array of size NEL containing initial element volumes. The incoming value is computed with one integration point, which can be recomputed. |
UVAR | Float array read write | Array of size NEL*NUVAR containing user element variables. |
OFF | Float array read write | Array of size NEL containing deleted element
flags.
RHO | Float array read write | Array of size NEL containing current densities. |
SIG | Float array read write | Array of size 6*NEL containing current stress tensor SX, SY, SZ, SXY, SYZ, and SZX. |
XX1 | Float array read only | Array of size NEL containing X coordinate at node 1 in the global frame at time TIME. |
UX1 | Float array read only | Array of size NEL containing X displacement at node 1 in the global frame at time TIME. |
VX1 | Float array read only | Array of size NEL containing initial X velocity at node 1 in the global frame at time TIME. |
VRX1 | Float array read only | Array of size NEL containing initial X rotational velocity at node 1 in the global frame at time TIME. |
FX1 | Float array write only | Array of size NEL containing X force at node 1 at time TIME. |
MX1 | Float array write only | Array of size NEL containing X moment at node 1 at time TIME. |
STIFM | Float array write only | Array of size NEL containing element translational stiffness in time step computation. |
STIFR | Float array write only | Array of size NEL containing element rotational stiffness in time step computation. |
VISCM | Float array write only | Array of size NEL containing element translational viscosity in time step computation. |
VISCR | Float array write only | Array of size NEL containing element rotational viscosity in time step computation. |
- STIFM, STIFR, VISCM, and VISCR compute the nodal or element time step. MASS and XINER compute element time step.
- RHO and SIG are used for post-processing in time history and animation. The modification of these variables effects only output. RHO and SIG retain initial values, unless they are modified.
