Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of
nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box.
The purpose of this manual is to describe the numerical methods included in Radioss.
Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree
of freedom (DOF), and there can only be one constraint per DOF.
The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered
to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability
can be applied to a variety of computational problems.
A large variety of materials is used in the structural components and must be modeled in stress analysis problems.
For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the
behavior of the material.
This law defines as elastic-plastic material with thermal softening. When material approaches meting point, the yield
strength and shear modulus reduces to zero.
Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel
version SMP made possible the exploration of shared memory on processors.
This law is only used with solid brick and quadrilateral elements.
It models the elastic and plastic regions, similar to LAW2, with a nonlinear behavior of
pressure and without strain rate effect. The law is designed to simulate materials in
compression.
The stress-strain relationship for the material under tension is:(1)
The pressure and energy values are obtained by solving equation of state related to the material (/EOS).
Input requires Young's or the elastic modulus, , and Poisson's ratio, . These quantities are used only for the deviatoric part. The
plasticity material parameters are:
Yield stress
Hardening modulus
Hardening exponent
Maximum flow stress
Plastic strain at rupture
A pressure cut off, Pmin, can be given to limit the pressure in tension. The pressure cut off must be lower or
equal to zero. 図 1 shows a typical curve of the
hydrodynamic pressure. 図 1. Hydrodynamic Pressure Relationship
