General Surface to Surface Contact (TYPE17)
The interface is used in the modelling of surface-to-surface contact. It is a generalized form of TYPE16 interface in which the contact on the two quadratic surfaces are directly resolved without needs of gap as the Lagrange Multiplier Method is used (図 1). The contact is supposed to be sliding or tied.
図 1. Quadratic Surface to Quadratic Surface Contact
