Interface Overview
There are several different interface types available in Radioss. A brief overview of the different types and their applications.
TYPE1
Tied contact (boundary) between an ALE part and a Lagrangian part.
TYPE2
Tied contact
TYPE3
Used to simulate impacts and contacts on shell and solid elements. Surfaces should be simply convex.
TYPE5
Used to simulate impacts and contacts between a master surface and a list of slave nodes. Best suited for beam, truss and spring impacts on a surface.
TYPE6
Used to simulate impacts and contacts between two rigid surfaces.
TYPE7
A general interface that removes the limitations of TYPE3 and TYPE5.
TYPE8
Drawbead contact for stamping applications.
TYPE9
ALE Lagrange with void opening and free surface.
TYPE10
Tied after impact with or without rebound.
TYPE11
Edge to edge or line to line impact.
TYPE12
Connects 2 fluid meshes with free, tied or periodic options.
ALE or EULER or LAG/ALE or EULER or LAG.
TYPE14
Ellipsoidal surfaces to nodes contact.
TYPE15
Ellipsoidal surfaces to segments contact.
TYPE18
Coupling between a Lagrangian material and an ALE material.
TYPE19
General contact interface.
Node to segment contact and Edge to Edge contact.
Equivalent to one interface TYPE7 + one interface TYPE11.
TYPE20
Single surface, surface to surface with optional Edge to Edge contact.
No time step condition with soft penalty
TYPE21
Specific interface between a non-deformable master surface and a slave surface designed for stamping.
Each of these interfaces was developed for a specific application field. However, this application field is not the only selection criteria. Some limitations of the different algorithms used in each interface can also determine the choice.
The algorithm limitations concern mainly the search of the impacted segment. This search may be performed directly (TYPE7, TYPE10, and TYPE11 interfaces), or via a search of the nearest node (TYPE3, TYPE5, and TYPE6 interfaces).
Apart from the limitation of the nearest node search, some limitations exist for the choice between the segments connected to the nearest node. These limitations are the same for TYPE3, TYPE5 and TYPE6 interfaces.
TYPE3, TYPE5 and TYPE6 interfaces also have some limitations due to the orientation of the normal segment.
TYPE7 interface was written to emulate TYPE3 and TYPE5 interfaces without algorithm limitations. With this interface, each node can impact one or more segments, on both sides, on the edges or on the corners of the segments. The only limitation to this interface concerns high impact speed and/or small gap. For these situations the interface will continue to work properly, but the time step can decrease dramatically.
TYPE3, TYPE5 and TYPE7 interfaces are compatible with all Radioss kinematic options.
TYPE1 interface is a special option used with solid elements to provide mesh transition. TYPE1 interface is used to connect a Lagrangian and an ALE mesh.
TYPE2 interface is used to connect a fine and a coarse Lagrangian mesh.
All other interface types (TYPE3, TYPE4, TYPE5, TYPE6 and TYPE7) are used to simulate impacts and contacts.
A node may belong to several interfaces.
Surface (Segment) Definition
Surfaces or segments may be defined in different ways, depending on the type of element being used. For a four node three dimensional shell element, an element is a segment.
図 1. Shell Elements Segment
For a brick element, a segment is one face of the brick.
図 2. Brick Element Segment
For a two dimensional element, a segment is one side.
図 3. 2D Element Segment
