RD-T: 3000 Tensile Test Setup
This tutorial demonstrates how to simulate a uniaxial tensile test using a quarter size mesh with symmetric boundary conditions.
rd3500_tensile
図 1.
The model is reduced to one-quarter of the total mesh with symmetric boundary conditions to simulate the presence of the rest of the part.
rd3500_01
図 2.
The model description is as follows:
  • UNITS: Length (mm), Time (ms), Mass (kg), Force (kN) and Stress (GPa)
  • Simulation time Rootname_0001.rad [0 - 10.]
  • Boundary Conditions:
    • The 3 upper right nodes (TX, RY, and RZ)
    • A symmetry boundary condition on all bottom nodes (TY, RX, and RZ)
  • At the left side is applied a constant velocity = 1 mm/ms on -X direction.
  • Tensile test object dimensions = 11 x 100 with a uniform thickness = 1.7 mm
Johnson-Cook Elastic Plastic Material /MAT/PLAS_JOHNS (Aluminum 6063 T7)
[Rho_I] Initial density = 2.7e-6 Kg/mm3
[E] Young's modulus = 60.4 GPa
[nu] Poisson's ratio = 0.33
[a] Yield stress = 0.09026 GPa
[b] Hardening parameter = 0.22313 GPa
[n] Hardening exponent = 0.374618
[EPS_max] Failure plastic strain = 0.75
[SIG_max] Maximum stress = 0.175 GPa
Input file for this tutorial: TENSILE_0000.rad
Create and Assign a Material
  1. From the menu bar, select Model > Material.
  2. Right-click in the material list and select Create New > Elasto-plastic > Johnson-Cook (2).
  3. For Title, enter Aluminum. Enter all the material data listed above.
  4. In the bottom of the material window, right-click in the Support entry box and select Include picked parts icon selectpartgeneral-24.
    rd3000_include_pick_part_14
    図 3.
  5. Select the part in the モデリングウィンドウ (left-click).
  6. Right-click to validate the selection.
  7. Press Enter or click Save > Close.
Create and Assign a Property
  1. From the menu bar, select Model > Property.
  2. Right-click in the property list and select Create New > Surface > Shell (1).
  3. For Title, enter Pshell.
  4. For Shell Thickness, enter 1.7.
  5. In the bottom of the property window, right-click in the Support entry box and select the Include picked parts icon selectpartgeneral-24.
  6. Select the part in the モデリングウィンドウ.
  7. Right-click to validate the selection.
  8. Click Save > Close.
Define Boundary Conditions Representing Symmetry
  1. From the menu bar, select LoadCase > Boundary Condition.
  2. Right-click in the display list area and select Create New.
  3. For Name, enter constraint1 and click Save.
  4. Expand the folders Translation and Rotation.
  5. Right-click in the Support entry box, click Select in graphics and select the Add/Remove nodes by picking selection icon arrow_up to select the nodes in the モデリングウィンドウ, as shown in the figure below:
    rd3000_bc2
    図 4.
  6. Click Yes in the Dialog menu bar to validate your selection.
  7. To constrain the nodes, toggle Tx, Ry and Rz and click Save.
  8. Repeat the same operations to create constraint2, as shown in below:
    rd3000_node
    図 5.
  9. Toggle Tx, Ty, Tz, Rx, Ry and Rz, and click Save.
  10. Repeat the same operations to create constraint3, as shown in below.
  11. Press Shift, left-click and hold the mouse to draw a box to select the nodes.
    rd3000_constraint3
    図 6.
  12. Toggle Ty, Rx, and Rz.
  13. Click Save > Close.
Define Imposed Velocity
  1. From the menu bar, select LoadCase > Imposed > Imposed Velocity.
  3. Set the Title to imposed_velocity.
  4. Right-click in the entry box for Time function and select Define Function.
    A Function Window opens up.
  5. For Function name, enter FUNC_VEL.
  6. Enter the first point (0,1) and click Validate.
  7. Enter the second point (1e30,1) and click Validate.
  8. Click Save in the dialog.
  9. Right-click in the Support entry box, click Select in graphics and select the Add nodes by box selection icon selectbyboxadd-24, to select the nodes in the モデリングウィンドウ, as shown in below:
    rd3000_Yscale
    図 7.
  10. Go to the Properties tab and enter a Y-Scale factor = -1.
  11. Ensure Direction of the imposed velocity is set to X (translation).
  12. Click Save > Close.
Define a Time History Node
  1. From the menu bar, select Data History > Time History.
  2. In the list display area, right-click and select Create New > TH of nodes.
  3. Enter the title Node_79.
  4. Click Add Row addrow to add a new row.
  5. With that row selected, scroll down to the input section and enter NODid as 79 and press Enter.
    As an alternative, use the Pick button to select a node in the モデリングウィンドウ.
  6. Click Save > Close.
Export the Model
  1. From the menu bar, select Model > Control Card:
    control_card_menu
    図 8.
  2. Enter the values for the Control Cards, as shown in the images below, saving after every step:
    rd3000_control_card2
    図 9.
    rd3000_control_card4
    図 10.
    rd3000_control_card_tfile
    図 11.
    rd3000_anim_dt
    図 12.
    rd3000_anim_eltype_restype
    図 13.
    rd3000_anim_vect
    図 14.
  3. Click File > Export > Radioss to export the solver file.
  4. In the Write Block Format Radioss2020 File window that opens, navigate to your desired run directory and create a new folder named TENSILE_TEST.
  5. For filename, enter TENSILE and click OK.
  6. Leave the Header window empty and click on Save Model.
    The file TENSILE_0000.rad is written.
The model is now ready to run through the Starter and the Engine. It will produce the result files TENSILEA* for animation in HyperView and TENSILE01 for time history plotting in HyperGraph.
Expected Results
rd3000_contour_total_disp
図 15. Total Displacement Contour (mm)
rd3000_contour_plastic_strain
図 16. Plastic Strain Contour
