Starter Subroutine LECMUSERnn
This subroutine reads the user law input data.
The first seven material cards (see Radioss Starter Input Manual 3.1 to 4.1) are read before this subroutine is called.
The numbers and formats of specific material cards are free.
Arguments
LECMUSERnn
is:C--------------------------------------------------------------------------
SUBROUTINE LECMUSERnn(IIN, IOUT, UPARAM, MAXUPARAM,NUPARAM, NUVAR,IFUNC,MAXFUNC,NFUNC,PARMAT, USERBUF )
Argument | Format | Description |
IIN |
Integer read only scalar | Input file unit (ROOTD00, ROOT_nnnn.rad) on which the data are read. |
IOUT |
Integer read only format | Output file unit (ROOT_nnnn.lis). |
UPARAM
Float array | Array with a size NUPARAM used to store
failure material data. |
MAXUPARAM |
Integer read only scalar | Maximum possible size of UPARAM . |
NUPARAM |
Integer scalar | Effective size of UPARAM .
(MAXUPARAM , NUPARAM ,
MAXUPARAM are set to 1000). |
NUVAR |
Integer scalar | Number of extra variables needed for each integration point of each elements. |
IFUNC |
Integer array | Array with a size of NFUNC containing the
list of Radioss functions used in
failure model. The function numbers are stored in this array
(not in UPARAM ), due to a possible renumbering
of the function’s numbers. |
MAXFUNC |
Integer read only scalar | Maximum possible size of IFUNC . |
NFUNC |
Integer scalar | Number of Radioss functions. |
STIFINT |
Float scalar | Modulus needed to compute the interface stiffness. The Young’s or bulk modulus is used to define the value, which estimates the time step. |
USERBUF |
Data structure read write | Defined in LAW_USER.mod. This module is
used inside LECMUSERnn . |
USERBUF
data structure contains:
NAME |
Character array read only | Array of size 100 containing material name. |
ID |
Integer read only scalar | Material ID defined in Starter input
deck. |
