udfGetSdNElms()
Return the number of element sets in the subdomain.
nElms = udfGetSdNElms( udfHd ) ;
AcuSolve User-Defined Subdomain Routine
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
nElms (integer)
Number of element sets in the subdomain.
This routine returns the number of element sets in the current subdomain. For example,
Integer nElms ;
  • This routine expects a valid udfHd.
  • This routine may only be called within an external code.
