Challenges in Simulating Turbulent Flows
In order to set the context for the modeling of turbulent flow it is essential to understand why turbulent flow simulations are challenging.
Figure 1. Snapshots of Smoke Plumes
View new features for AcuSolve 2021.
AcuSolve is a leading general purpose CFD solver that is capable of solving the most demanding industrial and scientific applications.
Discover AcuSolve functionality with interactive tutorials.
Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
This section on mathematical background covers the various notations and operators used to formulate and define the equations of fluid flow.
This section on basics of fluid mechanics covers topics describing the fundamental concepts of fluid mechanics, such as the concept of continuum, the governing equations of a fluid flow, definition of similitude and importance of non-dimensional numbers, different types of flow models and boundary layer theory.
This section on turbulence covers the topics describing the physics of turbulence and turbulent flow. It also covers the modeling of turbulence with brief descriptions of commonly used turbulence models.
This section on physics of turbulence introduces a brief history of turbulence and covers the theory behind turbulence generation, turbulence transition and energy cascade in fluid flows.
This section covers the numerical modeling of turbulence by various turbulence models, near wall modeling and inlet turbulence parameters specified for turbulence models.
The Navier-Stokes (NS) equations are the set of equations that govern the motion of a fluid.
Direct Numerical Simulation (DNS) solves the time dependent Navier-Stokes equations, resolving from the largest length scale of a computational domain size to the smallest length scale of turbulence eddy (Kolmogorov length scale).
Three-dimensional industrial scale problems are concerned with the time averaged (mean) flow, not the instantaneous motion. The preferred approach is to model turbulence using simplifying approximations, and not resolve it.
For incompressible turbulent flow the instantaneous velocity field can be decomposed into a time averaged velocity and its corresponding fluctuation.
All of the previously described models are incapable of predicting boundary layer transition. To include the effects of transition additional equations are necessary.
LES is often regarded as an impractical tool for industrial CFD applications as it requires large computational resources.
In recent years, hybrid methods have increasingly been employed for the simulation of unsteady turbulent flows.
For internal wall bounded flows, proper mesh resolution is required in order to calculate the steep gradients of the velocity components, turbulent kinetic energy, dissipation, as well as the temperature.
CFD simulations require specification of turbulence variables at inlet boundaries.
During the past decades turbulence models of various complexities have been developed. Turbulence models that employ the most assumptions are typically the least demanding from a CPU cost standpoint.
This section on numerical approximation techniques covers topics, which describe the numerical modeling of the fluid flow equations on a computational domain, such as spatial discretization using finite difference, finite element and finite volume techniques, temporal discretization and solution methods.
This section on AcuSolve solver features covers the description of various solver features available in AcuSolve such as heat transfer, fluid structure interaction and turbulence modeling.
Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy of AcuSolve results.
AcuSolve command descriptions and corresponding examples.
AcuSolve utility programs covering preparatory and post-processing as well as user-defined functions and utility scripts.
Customization of AcuSolve allowing you to customize certain capabilities of the solver.
Instruction of the mesh generation capability in AcuConsole, a GUI based pre-processor for AcuSolve.
Customization of AcuConsole allowing you to improve your particular workflow.
Commands of AcuTrace, a particle tracer that runs as a post-processor to or a co-processor with AcuSolve.
Instructions to define additional solution quantities of AcuTrace called user equations.
Usage of AcuFieldView, an OEM version of Intelligent Light’s FieldView post-processing software.
Instruction of the AcuReport tool, a standalone post-processor batch tool used to generate a report from an AcuSolve solution database.
