QUIT
Terminates parsing the input file.
AcuSolve Command
QUIT {parameters}
Qualifier
This command has no qualifier.
This command has no parameters.
This functional command terminates reading (parsing) the input file.
For example,
ANALYSIS {
 title = "test problem"
QUIT # check the commands read up to this point
This command is typically used for debugging. Note that the RUN command, which is typically placed at the end of a file, also terminates the parsing of the input file. EXIT may also be used as an alternative command name for QUIT.
