getSrfActor()
Return surface actor specified by its information.
Usage
srfActor = vis.getSrfActor( srfInfo )
srfInfo (integer) or (string)
Name or ID of a surface.
Return Value
srfActor (object)
Surface actor corresponding to the srfInfo.
srfInfo should be valid.
This routine returns the surface actor specified by its name or ID which is given by srfInfo. For example,
fan = vis.getSrfActor( "impeller" )
