getPbcActor()
Return periodic actor specified by its information.
Usage
pbcActor = vis.getPbcActor( pbcInfo )
pbcInfo (integer) or (string)
Name or ID of a periodic.
Return Value
pbcActor (object)
Periodic actor corresponding to the pbcInfo.
pbcInfo should be valid.
This routine returns the periodic actor specified by its name or ID which is given by pbcInfo. For example,
pbc = vis.getPbcActor( 0 )
