Computational Surface Panel
Use the Computational Surface panel to visualize data on the computational mesh.
A computational grid is a set of points in IJK space, with XYZ position values defined for each point. A Computational Surface is a plane in IJK space, that is, a surface of constant I or J or K in a single grid, which may be curved in XYZ space. This panel is only available for structured grids.
