Manufacturing Solutions
Typical Material Properties
This chart lists some typical properties for metal forming materials.
This information adapted from the High Strength Steel Stamping Design Manual, copyright 1994, Auto/Steel Partnership.
Material
Grade
Yield Strength (ksi)
Tensile Strength (ksi)
Total Elong (%)
n value
r value
Hardness
Rb
Width Range
(inch)
Thickness Range
(inch)
HR
DQSK
34.0
48.0
42
0.20
1.1
54
24 to 72
.055-.375
HR
DQ
35.7
49.1
40
0.19
1.1
55
24 to 72
.055-.375
HR
CQ
38.9
56.0
39
0.19
NA
60
24 to 72
.055-.375
CR
EDDQ
20.0
44.0
49
0.26
1.9
30
24 to 72
.015-.080
CR
DQSK
26.5
45.0
44
0.23
1.8
36
24 to 72
.015-.130
CR
DQ
27.0
45.8
42
0.22
1.6
40
24 to 72
.015-.130
CR
CQ
30.2
47.0
41
0.20
1.3
45
24 to 72
.015-.130
HDG(CR)
EDDQ
22.4
44.9
46
0.25
1.9
32
24 to 72
.015-.170
HDG(CR)
DQSK
28.4
45.8
44
0.23
1.6
40
24 to 72
.015-.170
HDG(CR)
DQ
35.7
49.6
41
0.20
1.3
52
24 to 72
.015-.170
HDG(CR)
CQ
40.6
53.0
35
0.17
1.2
58
24 to 72
.015-.170
GA (CR)
EDDQ
22.0
44.7
48
0.25
1.9
32
24 to 72
.015-.170
GA (CR)
DQSK
24.5
46.0
45
0.22
1.6
45
24 to 72
.015-.170
GA (CR)
DQ
32.3
47.6
42
NA
NA
49
24 to 72
.015-.170
GA (CR)
SQ30
36.0
51.9
37
NA
NA
55
24 to 72
.020-.170
Alum(CR)
IF
25.0
44.0
43
0.24
1.7
37
24 to 60
.015-.140
Alum(CR)
EDDQ
26.0
44.0
46
0.24
1.6
39
24 to 60
.015-.140
Alum(CR)
DDQ1
26.0
44.0
45
0.21
1.3
45
24 to 60
.015-.140
Alum(CR)
DQSK
32.0
50.0
39
0.21
1.2
47
24 to 60
.015-.140
Alum(CR)
DQ
34.0
49.0
41
0.21
1.2
47
24 to 60
.015-.140
Alum(CR)
CQ
47.0
56.0
32
NA
1.2
60
24 to 60
.015-.140
