Manufacturing Solutions
To specify the animation simplification style
1.Open the Options panel.
2.Select the graphics subpanel.
3.Click the switch after view simplification: and select feature lines, bounding box, node cloud, or element centroid.
If you select feature lines, the model is simplified to display only feature lines during view accelerations.
If you select simplified shading, the model is drawn with shading only (for example no mesh lines, feature lines, etc.) during view accelerations.
If you select bounding box, each component in the model is represented by a wireframe bounding box during view accelerations.
If you select node cloud, the model is simplified to display the components as node clouds during animation.
If you select element centroid, the model is simplified to display only the elements centroids during animation.
Obviously, none removes any previously-chosen view simplification method.
4.Activate the simplify current comp check box if you want to simplify the current component along with the rest of the model during view accelerations.
