Manufacturing Solutions
Importing HyperForm Model Files
There are two methods for using HyperForm model files, both accessed from the File menu:
Open deletes the current HyperForm session and opens the selected HyperForm model file in a new session.
Import allows you to import a single or multiple HyperForm model files into the current session without deleting the current session.
To Open a HyperForm Model File:
1.Click File > Open > Model to browse for the .hf file to open, or click Open Model fileOpenModel-24 on the Standard toolbar.
You can only open one model file at a time.
2.Once the file is selected, click Open to open the file.
To Import a HyperForm Model File:
1.Click File > Import > Model or click the Import Model icon fileImportModel-24 on the Standard toolbar. This displays the Import tab.
2.Click the Select File icon fileOpen-24 to choose the file to import. Selected files are displayed in the File Selection window. You can use the Remove Selection tableDeleteSelected-24 and Remove All tableDeleteAll-24 icons to quickly remove files from the window.
You can import any number of HyperForm files.
3.Once the file is selected, click Import.
See Also:
Importing and Exporting Data
