Manufacturing Solutions
To create torus surface primitives by specifying the center and radius
1.Select the Surfaces panel, torus center and radius subpanel.
2.Click on the center collector and select a node from the graphics area.
3.Click on the normal vector collector and select a node from the graphics area.
4.Enter the major radius value.
5.Enter the minor radius value.
6.Click create.
7.To undo, immediately click reject.
